Python Programming In Civil Engineering Project
MatthewMansfield
GB
Hello All
I was wondering if anyone had any research project ideas in the field of Civil Engineering but includes the use of the Python Programming Language.
I am trying to learn the Python Programming Language and I thought it would be a good idea to combine Python with a Civil Engineering project i think it would be a very good learning experience.
Does anyone have any ideas?
Thank you.
MatthewMansfield,
Learning Python is on my to-do list. I know Perl fairly well. Python and Perl are used to write online applications. I have written a Perl application that searches my hard drive for JPEGS. It rejects the low resolution ones, it corrects the camera rotation if necessary, and it builds a slide show. What do you want to accomplish?
I cannot think of many apps I would hire a civil engineer to write. If you are doing engineering calculations, you should learn MatLab and Octave.
JHG
Since Python is a go-to language for machine learning, it would seem plausible that you might find some way of combining machine learning with CE
TTFN (ta ta for now)
Yup, fore xample many years ago I built an FEA program that selected the correct section size for each tube from the available ones given a constraint of stiffness and mass of the total structure. That is NOT the same as a general optimisation, because if you make 1 section larger than optimum because the optimum isn't available then you may be able to reduce the size of another one.
Cheers
Greg Locock
