NACA symmetrical foils - How do I find the point of balance ?
I'm designing a T Foil rudder to go on the bottom of an existing catamaran. I would like to include an engagement/disengagement mechanism that can be used in motion. To simplify and reduce weight in the control I'd like to position the pivot slightly ahead of the point of balance.
Is there a general rule for positioning this ? Does it move with AOA ? In use they will be set at rest at 0°.
I'm likely to use 0008 to 0012 foils.
Dave
Dave
RE: NACA symmetrical foils - How do I find the point of balance ?
https://ntrs.nasa.gov/citations/19930090976
Cheers
Greg Locock
The standard reference point for the pitching moment is 0.25*chord, called the "quarter-chord".
The negative moment implies the actual "aerodynamic center" is forward of the quarter-chord point. The rest is just a balance of forces.
www.sparweb.ca
