Mirrored Extent Option enable for 3D line in CATIA VBA
Hi siva
This is regarding Mirrored Extent Enable Option for 3D line in CATIA R24
I had used the following syntax for surface to get mirrored extent.
surface1.SymmetricalExtension = 0
likewise what is the code for mirror extend for 3D LINE in Catia?
i tried using same as in surface with setsymmetricalextension
line1.setsymmetricalextension = 0
but i get compile error: argument not an option.
Advises please, thanks in advance
RE: Mirrored Extent Option enable for 3D line in CATIA VBA
I don't see that option in the line creation, only 2 offset values.
Func AddNewLinePtDir( Reference iPt,
HybridShapeDirection iDirection,
double iBeginOffset,
double iEndOffset,
boolean iOrientation) As HybridShapeLinePtDir
This works but be sure your beginoffset value is 0 and your desired length is the endoffset value.
CODE --> CATVBA
Set hybridShapeLinePtDir1 = hybridShapeFactory1.AddNewLinePtDir(reference1, hybridShapeDirection1, 0, 60, False)
hybridShapeLinePtDir1.SetSymmetricalExtension (1)
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - The Future of Product Development is Here
Looking to make the design and manufacturing of your products more agile? For engineering and manufacturing organizations, the need for digital transformation of product development processes just became more urgent than ever so we wanted to share an eBook that will help you build a practical roadmap for your journey. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
