Mirrored Extent Option enable for 3D line in CATIA VBA
AVIS0202
Automotive
IN
Hi siva
This is regarding Mirrored Extent Enable Option for 3D line in CATIA R24
I had used the following syntax for surface to get mirrored extent.
surface1.SymmetricalExtension = 0
likewise what is the code for mirror extend for 3D LINE in Catia?
i tried using same as in surface with setsymmetricalextension
line1.setsymmetricalextension = 0
but i get compile error: argument not an option.
Advises please, thanks in advance
I don't see that option in the line creation, only 2 offset values.
Func AddNewLinePtDir( Reference iPt,
HybridShapeDirection iDirection,
double iBeginOffset,
double iEndOffset,
boolean iOrientation) As HybridShapeLinePtDir
This works but be sure your beginoffset value is 0 and your desired length is the endoffset value.
Code:
Set hybridShapeLinePtDir1 = hybridShapeFactory1.AddNewLinePtDir(reference1, hybridShapeDirection1, 0, 60, False)
hybridShapeLinePtDir1.SetSymmetricalExtension (1)
