ETABS v18 Errors/Issues
Trenno
831
Is anyone else out there having issues with ETABS v18 and it being very buggy?
Sample errors below. Something isn't clicking over properly under the hood...
I have not experienced this error at all. The Current version is 18.1.1. Is it possible that you're running a version that is slightly older?
Have you tried sending your model in to the CSI tech support?
I find when I come up against these type of things simply opening and restarting etabs generally solves them.
Some of these types of errors you click ok and the same window comes up again and again in an infinite loop. Quit it via task manager and a relaunching etabs usually solves it and allows you to do whatever was trying to be done.
