buckling beam
Hi my fellows engineers!
I'm an italian strucutral engineer, working as an independent consultant, and I'm here to share with you a new problem and maybe get some solutions/tips.
Here's the thing: yesterday, I went to an office building (inside a warehouse) which is meant to go under renovations beacause of covid-19 (they need extra space between working places and larger circulation corridors). Among some easy stuff to calculate, there's a column at the entrance that needs to be removed, so they can have a bigger entrance door to allow 2 separate corridors - one to enter and one to leave. Attached you can find 2 drawing: one showing the existent and another showing my idea to solve this problem.
My doubts are basically:
- connection between UPN beam and existing concrete beam with anchor bolts in site?
- torsion moment in the UPN beam?
- bolts only in the width of the existing column or over the length of UPN beam?
- calculate the smash of UPN beam web like we do with steel base plates?
I can't put a beam under the concrete beam already there because there's no height....
Any help would be very much appreciated!!
