Contact US
Vibration at floor level (steel beams and wood joists)
so there isn't any vibration criteria in code books,I wonder how others would approach to this problem.
I've got a dancing room which is supported by steel beams and wood I-joists.
Although all the members pass the design criteria, the vibration is now the problem after the construction completion.
I have come across the following statements,
1. increasing stiffness increases natural frequency
2. increasing mass lowers natural frequency
However, I have also seen other report where it states that increasing stiffness will cause the increase in fundamental frequency and that could mitigate vibration as a result. So this means both natural and fundamental frequency increase, and wouldn't this be both good and bad?
Also, in the same report, adding mass lowers vibration level at resonance (by means of lowering natural frequency I believe) but also lowers the fundamental frequency. So, isn't this both good and bad too?
On top of that, I believed reducing the "gap" between natural and fundamental frequency would mean lowering amplitude but I'm not too sure if amplitude has anything to do with vibration matter.
I know there's certain suggested frequency to avoid vibration, so would all these approaches be simply trial and error?
RE: Vibration at floor level (steel beams and wood joists)
Structural Engineer magazine had an article on this a few years ago. Vibration of wood supported floor systems. Essentially they used the same procedures that the AISC design guide uses. But, they formulated them a little differently.
Unfortunately, that magazine is now defunct, so I can't give you a link to the article. But, I think this article is essentially the same, or very close.
https://www.woodworks.org/wp-content/uploads/seaoo...
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
