Separation distance from footing drain of building to underground stormwater storage/leaching chambe
Is there a required separation distance between a footing drain and a drywell surrounded by stone for stormwater storage ?
I am familiar with the separation distances for subsurface sewage disposal , was not certain about storwater runoff ?
RE: Separation distance from footing drain of building to underground stormwater storage/leaching chambe
Not sure you find that posting, but using the words "bentonite" and maybe "drainage' and you will find it. If needed, I can repeat it here.
