They can't be that precise on the torque splitting - and they aren't, and won't be.
In particular, if you are rounding a sharp corner, the front wheels will carve a longer trajectory than the rear, and it will not be possible to transmit any forward torque to the front drivetrain at all (any engagement of this clutch will try to drag the front wheels and drive the rears).
... unless you are spinning the rear tires while rounding the corner ... then beyond a certain slip percentage, it will start to be able to drive the fronts.
