Naming of Analysis File in FEMAP Using Local Solver?
General FEMAP/Nastran question:
I've been used to using VisQ with a remote solver setup where I could export the analysis file to a specific name (i.e. "200820_Free_Free_Modes_Check.dat") then send the analysis file off to the server and have nicely named output files created.
My new company uses local, embedded Nastran within FEMAP instead of a remote solver setup. In this case, my files names are written out automatically when I analyze as "MODELNAME-000.XXX". Is there anyway to specify a unique file name prior to analysis or even a way for me to solve using the VisQ process locally so that I can write out my .dat files with a descriptive/useful name?
I've searched everywhere and can't seem to find any information.
Thank you!
-CH
Thank you!
-CH
RE: Naming of Analysis File in FEMAP Using Local Solver?
Is very easy, you can right mouse click in your analysis study and select EXPORT, this will open an MS-DOS window where you can enter your preferred NASTRAN input file name.
Next open the MS-DOS window where you can run the Simcenter Nastran solver simply using "nastran your-model.dat + nastran_keywords, etc..". You need to include the nastran solver in your PATH environment.
To learn more visit my blog:
https://iberisa.wordpress.com/2014/01/03/requisito...
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48004 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
Thank you for the link as well Blas, very helpful and much appreciated!
-CH
