dynamic viscosity coefficient iso vg 32
Hello dear friends.
Please, share an information of dynamic viscosity coefficien for iso vg 32 oil for various temperature.
RE: dynamic viscosity coefficient iso vg 32
thread391-314986: Oil data reduction
It requires input of viscosity at two different temperatures.
You have viscosity = 32 cSt at 40C.
We need viscosity index to figure out figure out viscosity at 100C... do you have a viscosity index for your oil?
(2B)+(2B)' ?
The suggested spreadsheet will give you a useful indication of the dynamic viscosity at other temperatures - if you want the dynamic viscosity you will need to multiply the outcome with the density of the fluid at the same temperature of the viscosity measured.
You do not need the viscosity-index to get the viscosity data at various temperatures. However, if you want the VI, it can be calculated - in the appendix of ASTM D2270 you can find how to. If you do have the viscosity at 40 and 100 deg C you can also find a calculation tool on the internet: https://wiki.anton-paar.com/nl-en/astm-d2270-visco...
If you only want to know the dynamic viscosity at a certain non-standard temperature the easiest way is to have that measured in a laboratory.
It follows a predictable pattern which can be determined only if you know the viscosity index or the viscosity at one other temperature (besides 40C where viscosity is 32 cSt).
The further you are projecting away from the reference temperature 40C, the larger the error you might encounter from some arbitrary assumption embodied in the chart.
(2B)+(2B)' ?
