Pyrolysis of aluminum waste
Why pyrolysis of aluminium waste in a fluidized bed reactor with air generating so many boulders and crystallites in the outlet line? Is it because of aluminum oxide or Zinc/tin oxide formation. The inpout material has (99.99% aluminum) + plastic waste.
RE: Pyrolysis of aluminum waste
I'm not familiar with pyrolysis, but from what I understand temperatures are normally kept well under the normal oxidation temp for aluminum. What color are the boulders and crystals? If it were alumina or other metal oxides I would expect them to be white (on the inside anyways, the outside might be covered with char from the plastic decomposition).
Also, what is the operating temperature of the fluidized bed reactor? I've operated similar reactors (completely different application) in the past with aluminum and know that at temperatures above around 550 C or a bit higher, aluminum gets soft and can begin to sinter. These sintered particles can tend to grow and grow into huge masses that eventually shut the reactor down.
OP has left the building...
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Solutions Brief - Protecting and Rescuing On-Ground Personnel
Keeping our warfighters safe and delivering them a competitive advantage is a key goal of departments of defense around the world. It’s a goal shared by embedded computing manufacturers like Abaco: we never forget who we serve.This case study describes how a major international contractor integrated an Abaco single board computer at the heart of its CAS/CSAR solution. Download Now
Datasheet - Top Enhancements Creo 7.0
PTC's Creo 7.0 has breakthrough innovations in the areas of generative design, real-time simulation, multibody design, additive manufacturing, and more! With Creo 7.0, you will be able to design the most innovative products faster than ever before, keeping you on the cutting edge of product design and ahead of your competition. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
