RS2 - Setting Support and Displacements
GeoQuestion
Geotechnical
BR
The displacements that I find on Interpret do not change after add bolts (Fully bonded and End anchored).
How can it be possible? I inserted tensile capacity, bolt modulus, etc..
Perhaps you have not added enough tension to resist shear displacement? Also, just check that you have recalculated the problem and not just viewing an old calculation.
