What's the correct way to wire a reflective optical sensor?
Ziv Z.
10
I'm trying to use a reflective object sensor, in order to detect a label on a moving liner and once detected send a command to a motor.
I have the following sensors:
OPB732WZ
OPB745WZ
OPB740wz
all from Optek.
What's the correct way to connect them to a circuit to get the most accurate result/most sensitivity?
Read the manual or hire an electrician, if you do not have the appropriate skills.
