Salt water disposal well corrosion - SAGD process
demsha
Materials
CA
Dear friends,
I am working on the Well Integrity Management Program for SAGD wells. Can anyone suggests where I can find information on [highlight #FCE94F]corrosion of saltwater disposal wells? including casings and downhole tube[/highlight]
Appreciated
Google will probably take you to OnePetro with one of its first hits. NACE conference papers might also be up in the top five.
Steve Jones
Corrosion Management Consultant
All answers are personal opinions only and are in no way connected with any employer.
Thanks for the information. But it doesn't help me.
This is a good place to start:
The technical library at NI has a lot of good reference materials.
You have to assume that the disposal water is oxygen saturated. These chew up nearly all metals. It is tough service.
So, you can't plug "produced water disposal well corrosion" into Google?
Steve Jones
Thanks for all answers. To answer Sjones comment, Google doesn't give leads to specific areas of corrosion I am looking for. I am looking SAGD SWD casing and tubing corrosion problems.
Can't it just be produced water? What will be so different with SAGD produced water?
Steve Jones
Demsha. If you want more specific answers then you need to provide more specific data.
Such as chloride level, o2 level, temp, pressure etc. Anything specific to SAGD.
There's lots of info here and out there on corrosion from salt water.
What material are you thinking of our using now. Warm/hit aerated salt water is very corrosive to many metals. How much money do you have?
This isn't actually any different than people that inject seawater for formation support.
It may have different impurities, but in the end it is oxygenated salt water.
Knowing the temperature and pH will allow you to put a range on materials that are likely candidates for service.
You are in place, you should teach us about the question you are putting about. I would like to help you.
luis
