How to change Pipe segment Diameter? (CREO 4.0)
Fernandoomi
Automotive
BR
I would like to know how can I change the Pipe Diameter from a piping segment.
I made my design not using the "Spec Driven" option.
I tryed going on "Modify", in modify Options marked "Line Stock", then I selected the segment, and finaly on the "Modify Linestock" I changed from the 4 inches to 3 inches as I needed. The problem is that the Ok button is greyed-out. I even tryed to create a new and added a new linestock it stays the same.
Is it possible it is preventing the change because there is no transition that would allow a different diameter?
