Does passivation help against Chromium Carbide precipitation?
trainguy
CA
All,
2 questions:
1) Is it possible to get chromium carbide precipitation in a low-carbon stainless steel grade, such as AISI 301LN?
2) Will passivation of 301LN stainless prevent carbide precipitation?
Thanks!
tg
Carbide precipitation is a heat issue. The material needs to be annealed and rapidly quenched to prevent carbide precipitation. Surface treatments will not correct carbide precipitation.
1) After a very long period of time. But SS with carbon content less than 0.020% is immune for all practical purposes. Add Nitrogen and you may have Cr2N precipitation, but I haven't encountered that in any literature. Process this alloy with due attention to time at temperature and this steel's corrosion resistance will be alright (and because it is L grade, unlikely to be specified for high temperature service where damage can happen).
2) No. The two phenomena are unrelated.
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
