Applying Area Loads to Beam Model 1
MegaStructures
Hello: I have a large beam model in FEMAP that I would like to apply area loads to. The beams in reality will have a steel deck plate on top of them and per code a 75 psf distributed load must be applied to the beams. I cannot figure out a way to apply a distributed load to these beams, without manually calculating the tributary area of each beam and applying load onto each individual beam. There must be a way to add a distributed load to a beam model in FEMAP, similar to structural programs such as STAAD and Risa. Any suggestions are highly appreciated.
Edit: I should also mention that node and beam spacing is irregular, so manually calculating nodal loads, or linear beam loads would be extremely cumbersome
yep, you'll need to figure out the tributary area … 1/2 the distance to the adjacent beams ?
this is a model of a beam in isolation, or is the beam part of a larger model ?
Thanks for the reply rb1957. It's a model made up of 100's of beam elements arranged in a way that makes the bending from the deck plate 'two-way' bending. The other possibility I though of was modeling the deck plate as a surface and applying a force per area to that, but I ran into an additional problem that I cannot connect the deck plate along the beams.
why not model the deck plate, and apply pressure load ?
I would like to do that, but cannot think up a way to connect the deck plate to the beams.
Edit: To be clear the beams are actually beam elements, they are not beams made with shell elements.
understood, beams as BEAM elements, nodes close to NA.
plate on the nodes. if you're using it as a loading surface, make it reduced properties (E = 0.1*E, t = 0.01", …)
Hello!,
In FEMAP you have the DATA SURFACE EDITOR, take a look to the enormous capabilities of this feature. “Data Surfaces” allow you to apply vari­able loading conditions using a number of predefined methods.
Take a look to this training material:
(34 MB)
Also, take a look to SDC VERIFIER for FEMAP in my blog, no limits!:
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48004 BILBAO (SPAIN)
WEB: Blog de FEMAP & NX Nastran:
Blas, can a pressure force be applied to a data surface, or is the only option to create nodal loads?
