Groups are infected with entities which do not belong to.
Mustafa_Aerospace
Aerospace
NL
When I copy/modify/manipulate/edit entities in an active group other groups are infected with entities which do not belong to.
It is a highly irritating problem and it is too much time consuming to clean up the groups.
Does anyone have a solution for this irritating problem?
do you have group operations set to "automatically add to active group" ?
Hello rb1957,
Thank you for your response.
Just a single group can be activated for automatically adding elements at a time. The irritating (funny) thing is, that many other groups are infected with nodes, elements, lines, surfaces etc. when entities are copied/manipulated in the active/automatically adding activated group.
I'd call the help desk, they can be very helpful. Be prepared to share your model with them, or else (at a minimum) explain the issue to them in detail.
