Book on Factory Design
3
Hi everybody,
I'm wondering whether there is any book which collects ideas regarding design of factories, for example common pitfalls that plant designers should avoid or collection of great ideas in production lines,...
Any recommendation will be highly appreciated.
Nothing is more fairly distributed than common sense: no one thinks he needs more of it than he already has. Rene Descartes
RE: Book on Factory Design
"Factory Design" covers many areas and types of analysis. It is generally clumped together in the Industrial & Manufacturing Engineering fields of study:
  • manufacturing metrics analysis (cycle times, capacities, etc.)
  • determination & specification of production system that will go into the factory: single/multiple stations, cellular, manual/automated, etc., material handling & storage, etc.
  • cellular manufacturing & group technology for optimized processes
  • physical plant layout for lean manufacturing design, material flow, line balancing, etc.
  • worker ergonomics
  • production system administration
  • and a bunch of other things that must happen for it all to be moderately successful like training, signage, inventory control, etc.
I've done this for my entire career and now teach a course in it. I've not been able to find a single, good textbook. Some sources for you to investigate:
  • textbooks in Industrial & Manufacturing Engineering by Groover (even the older versions are still relevant and can be obtained inexpensively)
  • many textbooks on factory layout design are on the market
  • one of the most comprehensive single books I have found is a hard-core, old-school, badly written, unattractive spiral bound work book from SME called Planning Manufacturing Cells. It was developed by (presumably) successful Industrial Engineering consultants doing this type of work for money. The information & method is good, but students hated it...requires reading & digesting the info
  • There are a couple useful chapters in Maynard's Handbook of Industrial Engineering for this type of content
I'm not advertising because the jury is still out on the utility of this software. But for my next semester I investigating using Autodesk's Factory Design Utilities suite for my course. It has some interesting features to throw down 2D AutoCAD layouts, easily convert to 3D Inventor models, easily convert to something called Navisworks for collision/interference checking, group review & comment, visualize animated walkthroughs, then use their attempt at Discrete Event Simulation (a package they call Process Analysis) to simulate production and verify throughputs. It sure looks interesting, but it is a poorly-explained solution to a complicated niche-market and their marketing is simply awful IMHO.
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
Thanks tygerdawg for your elaborate response.
Actually, my interest is more on "collection of ideas" aspect of the book. In my career, I've visited a lot of factories and in each of them I saw a/some mechanism/mechanisms (in the production line, for example) that shows sort of ingenuity. For example, In a ceramic tile production line, the tiles shall be turned over every other one in order to have the embossing side not touching the flat side (after stacking them before going into the oven). The designer solved this problem in a simple way during movement of tiles on the conveyor. I mostly seeking a book with collection of these kind of ideas.
There's a publication called "Plant Engineering" you might want to look into.
When I was in school, long ago, I used Manufacturing Facilities by Sule. It may be completely out of date for certain manufacturing processes, but it covers a LOT of processes, and many of them haven't fundamentally changed much. I have no idea if it was better or worse than other books on the matter, but at least you have a name to look up and decide for yourself.
www.sparweb.ca
I once designed small manufacturing facilities for Lockheed, usually PEMB's housing rows of parts assembly stations. Most important: Where are the restrooms?! Next: Where is the break room?!
Actually, the big deal was how to get all the utilities to each station. We ran an elaborate cover-plated floor trench system.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Simulation-Driven Design with SOLIDWORKS
Simulation-driven design can reduce the time and cost of product development. In this engineering.com eBook, we’ll explore how SOLIDWORKS users can access simulation-driven design through the SOLIDWORKS Simulation suite of analysis tools. Download Now
eBook - Integrating the Engineering Ecosystem
Aras Innovator provides multiple options for integrating data between systems, depending on the scenario. Utilizing the right approach to meet specific business requirements is vital. These needs range from authoring tools, federating data from various and dissimilar databases, and triggering processes and workflows. Download Now
Research Report - Simulation-Driven Design for SOLIDWORKS Users
In this engineering.com research report, we discuss the rising role of simulation and the paradigm shift commonly called the democratization of simulation. In particular, we focus on how SOLIDWORKS users can take advantage of simulation-driven design through two analysis tools: SOLIDWORKS Simulation and 3DEXPERIENCE WORKS. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
