IBC and international codes 2
ramihabchi
98
IBC being an international building code does it mean that it could be used with any material code worldwide?for example BAEL or Eurocode
Check the Reference Standards in Chapter 35 for any Amended edition of the IBC you might be using. That will tell you what is to be expected by the Local Building Official. While it is called the "International" codes, it is generally North American and US centric on the Reference Standards. The base I-Codes are US centric, so anything like structural steel shapes is to be to an ASTM Standard. There are alternate methods and materials provisions in the codes, that require the Local Building Official to approve the material.
EIT, Modular Building Industry
Warhamer is pretty close - they're more than US Centric, they were written specifically for the US. The "International" part of the title is more marketing gimmick than anything else. When they combined the major regional model codes back at the end of the 1990s, they wanted there to be no question that it was the "superior" code. At least one of the pre-IBC codes had "national" in the title, and the other came from a self proclaimed "international" organization - so the only way to be bigger than that in name is to call yourself an international code. (Here's a paper on the evolution of model codes in the US.) If you look through at anything relating to geographic location (wind loads, seismic loads, snow loads, etc.), it only gives data for the US or references more specific standards that only reference the US.
It's also important to understand that the IBC is NOT a building code - it's a model building code. That means it is essentially worthless until adopted by the authority having jurisdiction. In the US, that means that your state, county or city building department (depending upon how government authority and sovereignty is proportioned in the state, because it can vary) has passed a law referencing the IBC (or other I-codes) and making them law. Not sure how that works where you are, but I imagine there would be something similar.
All that said - the principals in the IBC could certainly be applied in other countries (and frequently are). The physics governing the performance of structures under load doesn't change based on geopolitical boundaries. You just have to understand how they fit together legally, and how the standards applicable to materials in your area compare to those in the US and how the codes interact.
We have a project Power Control Room (PCR)
and we will built the stair & platform at the 3'(W)x 7'(H) exterior door.
So we would like to know what is the minimum length and width of the platform (see red circles below) to comply with IBC-2015/ Section 1011.6 building code
when the door is opened onto the landing at 90 degree and the building serves an occupant load of five or less because our building type for storage of the electrical equipment and just have a few technicians/controls guys to monitor.
You need to start your own thread. And make sure you post the picture when you do.
