Welding Non-NACE Attachments to NACE Piping
Daniel_C
Petroleum
MY
Dear all,
Is there any standard or recommended practice that clearly states it's acceptable to weld non-NACE attachments (e.g., normal ASTM A1006-B pipe saddles, earthing/bonding lugs made of ASTM A36, etc.) to the external of a A106-B MR0103-compliant pipe? The piping is in sour service; hence the MR0103 requirement. The project specification does say that saddle material shall be the same as pipe material, but mistake has been made and hundreds of non-NACE A106-B saddles have been welded to NACE pipes.
I looked through MR0103 Nov 2015, and couldn't find any answer.
Thanks in advance.
I think you can use non-Nace carbon steel saddles providing they will be stress-relief heat-treated to ensure the hardness is less than 22HRC (Rockwell C hardness, equivalent to 248Hv or 237HB). NACE MR0103/ISO 17945, ‘Petroleum, petrochemical and natural gas industries Metallic materials resistant to sulfide stress cracking in corrosive petroleum refining environments’, is intended for onshore process plant.
See the link bellow
luis
hope it helps
Essentially, it's fine provided that the attachment weld zone, including the HAZ on the saddle side, meets the hardness requirements of MR0103. The problem in saying that will be: ASME IX was probably used as the welding standard, thus no account of the variation in hardenability of the various grades and heats of material has been made. Looks like you will be out with a portable hardness tester taking quite a few readings. Enjoy.
Steve Jones
Corrosion Management Consultant
All answers are personal opinions only and are in no way connected with any employer.
Dear 0707 and SJones,
Understood. Is there any official interpretation or API/EN etc. standard saying that it's ok to do so provided hardness value is maintained below the limit stated in MR0103 (thru PWHT)? I am the project owner in a refinery hoping to salvage the project schedule by avoiding unnecessary rework.
Is it common that projects out there allow welding non-NACE saddles to NACE piping?
Thanks again for your feedback.
Dear Daniel_C,
Actually this is a grey area. However, you need to carry out PWHT to all the attachments. If this is too big a job, raise a 'deviation'.
Regards.
DHURJATI SEN
Kolkata, India
As you are the project owner of a refinery and it was a work mistake and you want to salvage the project schedule by avoiding unnecessary rework, if you try to fallow the rules of MR0103, you "almost" are, self supported. Otherwise as owner of the project, you have the power to decide yourself, to refuse the work and charge the constructor for the problems caused.
luis
"1.2.1 This standard applies to all components of equipment exposed to sour refinery environments (see Paragraph 1.3)
where failure by SSC would (1) compromise the integrity of the pressure-containment system, (2) prevent the basic function
of the equipment, and/or (3) prevent the equipment from being restored to an operating condition while continuing to contain
pressure.
1.2.2 It is the responsibility of the user to determine the operating conditions and to specify when this standard applies."
1.2.1
Are the saddles "exposed?"
1.2.2
This is the philosophy that will NOT get you any interpretation other than 'end user to decide.'
Steve Jones
Dear all,
Thanks for the feedback. It is clear to me now that this is a shot I need to make.
Daniel
