Isolate Geometry
Isolate Geometry
Hola
I have a plane that was created referencing upstream geometry. I would like to fix this plane in space and remove references to parent geometry. I believe for a surface I can Copy Geom from withing the same part. What is the best way to do this for a plane? In Catia this can be done using 'isolate' command. In NX I can't remember, but it's possible.
RE: Isolate Geometry
THIS SIGNATURE IS INTENTIONALLY BLANK
