Good day, fuselage masters,
I have seen couple of really interesting frame designs on few aircraft structural skeletons.I have been thinking about certain fuselage structural elements. What are some of the benefits and cons of integral frames(inner flange attached to skin) vs floating frames(ie frame shear clipped to stringer and/or attached to skin with shear ties)? Which is more weight efficient? Would the answer change if frame is composite or metallic? Pressurized fuselage vs non-pressurized? Lightly loaded vs heavily loaded? Any wisdom is much appreciated.
