Tank Anchorage
Tank Anchorage
Tank Anchorage
Hi All
I have a question how to find the information below for Tank Anchorage :
-N [dless] = Number of bolts selected
-Db [mm] = Bolt nominal diameter
And if any one have the document AISI E-1 specification, Volume ll, part VII,
Tanks in advance
Best Regards
RE: Tank Anchorage
Is this an API-650 tank ?
API-650 contains rules about the number of anchor bolts, spacing and bolt sizes
MJCronin
Sr. Process Engineer
RE: Tank Anchorage
Assuming anchorage is required, calculate the minimum number of bolts required based on maximum bolt spacing, and round up to a multiple of 4.
Calculate root area required per bolt, look in tables of bolt properties to find what size bolt that is.
Include corrosion allowance and minimum bolt sizing requirements if applicable.
If the bolt size or the anchor chair comes up unreasonably large, then increase the number of bolts and try again.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Integrating the Engineering Ecosystem
Aras Innovator provides multiple options for integrating data between systems, depending on the scenario. Utilizing the right approach to meet specific business requirements is vital. These needs range from authoring tools, federating data from various and dissimilar databases, and triggering processes and workflows. Download Now
Research Report - Simulation-Driven Design for SOLIDWORKS Users
In this engineering.com research report, we discuss the rising role of simulation and the paradigm shift commonly called the democratization of simulation. In particular, we focus on how SOLIDWORKS users can take advantage of simulation-driven design through two analysis tools: SOLIDWORKS Simulation and 3DEXPERIENCE WORKS. Download Now
White Paper - Industry 4.0 and the Future of Engineering Education
With industries becoming more automated, more tech-driven and more complex, engineers need to keep their skills and knowledge up to date in order to stay on top of this wave—and to be prepared for the Industry 4.0 future. The University of Cincinnati offers two online Master of Engineering degree programs designed specifically for practicing engineers. Download Now
eBook - The Design Gridlock Manifesto
In this eBook, you’ll learn 6 ways old CAD technology slows your company down and hear how design teams have put those problems to rest. “The Design Gridlock Manifesto” shares first-hand modern CAD experiences from 15 companies around the world. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
