Contact US
Rational Method Flow Length
Can you use the rational method if the overland sheet flow is greater than 500 feet for non-urban or 300 feet for urban areas?
RE: Rational Method Flow Length
The sheet flow procedure was originally limited to a maximum length of 300 feet, although many agencies use a lower limit, sometimes as little as 50 feet, so you need to check your stormwater regulations.
BTW, it doesn't matter which runoff procedure you use (Rational method, SCS, etc) the issue of the sheet flow length is the same.
Peter Smart
HydroCAD Software
www.hydrocad.net
depending on the methodology, "rational method" time of concentration may not include any limitation to length of flow path (sheet flow or otherwise).
I was not suggesting a limit to the overall flow length, only to the portion that is evaluated as sheet flow.
Unless the surface is a perfect plane, sheet flow cannot persist for more then 50-300 feet. At some point the flow depth will start to vary and it will transition to a different flow regime. The sheet flow procedure is also limited to a flow depth of 1/10 foot.
See the National Engineering Handbook for complete details, including the length limitation.
https://directives.sc.egov.usda.gov/OpenNonWebCont...
Peter Smart
HydroCAD Software
www.hydrocad.net
while I agree with you, some methods do not distinguish the flow regime when calculating the Tc.
for example, see the method below which does not consider sheet flow at all:
Understood. There are various procedures that do not restrict the flow length. But the OP was specifically asking about "sheet flow", which has definite limitations on flow length, as indicated in my reply and referenced documents.
Peter Smart
HydroCAD Software
www.hydrocad.net
the OP question was whether he could use the rational method. if he uses the method I posted, than yes he can, if he uses the NRCS method, than no he must follow the requirements for sheet flow
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
