Contact US
COMMAND "DRAW SECTION CUT ...." IN DRAW MENU ON ETABS 18 DOES NOT WORK
In ETABS 18 I want to get the total CUTTING EFFORT at the base of various walls of my model, through the command "Draw Section Cut ...", this command DOES NOT WORK!
See Figure
Has anyone had this problem?
Is it a program defect? or will I need some configuration in ETABS?
regards
RE: COMMAND "DRAW SECTION CUT ...." IN DRAW MENU ON ETABS 18 DOES NOT WORK
It works for me. So, you click on it and you cannot draw a section cut on the elevation where you want it?
'DOES NOT WORK' - could be so many things from that description?
Thanks for your answer.
What is happening is that it does not respond when I start drawing the horizontal line on the walls of the first floor to obtain the total cut of all the walls at that level.
We already tried ETABS version 18.0.1 and 18.0.2
If version 18.1.1 still does the same thing then try contacting CSI to see if they can replicate and confirm an error.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
