Why we use HORIZONTAL catalytic reactor in sulfur recovery unit?
Shivanya
Petroleum
IN
Greetings,
Can anyone give insight on why we use HORIZONTAL reactor in sulfur recovery unit and not vertical reactor?
Thanks in advance,
Thanks in advance
Shivanya
It's dictated by the Process engineer and Design holder.
In my point of view it is because of exothermic reactions involved.
Endothermic reactions require heat energy while exothermic reactions release heat energy.
Because with the time of operation, the possibility of coke formation and fouling in a horizontal bed reactor is less evident than in vertical one, because the heat release in a horizontal bed has less distance to travel, a temperature peak be will less pernicious than in a vertical reactor due to the exothermic reaction involved.
In other words, in a vertical reactor the temperature peak has more distance to travel.
This consideration is based on my experience, there is nothing of scientific in this thesis.
good luck
regards
luis
