Design Pressure vs Operating Pressure (Too much difference)
Hello all, I hope everybody is safe!
I have a question that maybe can be very simple but I want to hear your comments also, thank you. The question is that, I see some datasheets says design pressure is 100 mbarg and operating pressure is 20 mbarg for storage tanks. How can be a difference between them that much?
They want to create N2 blanketing system inside of tank, it is okey but as a operating pressure it says "ATM". I think there is a misswriting or what do you think? Thank you.
RE: Design Pressure vs Operating Pressure (Too much difference)
Depends on your design code.
If you're talking API 650, then for atmospheric tanks the definition of "ATM" is 1kpA (10 mbar) or 4 inches water.
100 mbar is actually quite high as design and sometimes put there by mistake because someone wants to insert a figure instead of "ATM"
otherwise not easy to decide as we have few other details.
It depends.
In a lot of cases, somebody has picked an arbitrary number without any consideration of the effects.
In other cases, they are properly considering API 650 or 620 provisions for vent set points, overpressure to achieve flow, etc.
In some cases, they may be anticipating future changes, or may be designing all tanks on a site for the same pressure to avoid confusion later.
Note that tanks operate within a pressure range rather than a fixed "operating pressure". For a padded tank, that's the pressure range between the pad gas set pressure and the set pressure of the tank's breather device. For a non-padded tank it's the range between the vacuum vent set pressure and the breather vent set pressure. This is the "operating pressure range" and it should be optimized by weighing the cost for a higher design pressure against the benefit of minimizing tank vapor losses. Each application is different, and needs to be evaluated on a case-by-case basis.
If the tank contains a liquid that is volatile, and/or expensive, and/or harmful (personnel or environment), then one has the incentive to maximize the operating pressure range, which means an incentive to maximize the tank's design pressure.
For the tank we're discussing, we don't know the contents of this tank or the size of the tank. If this tank is large in diameter, or contains a inexpensive & nonvolatile liquid like mineral oil, then a design pressure of 10 mbarg is excessive. In other cases it may be very appropriate.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Integrating the Engineering Ecosystem
Aras Innovator provides multiple options for integrating data between systems, depending on the scenario. Utilizing the right approach to meet specific business requirements is vital. These needs range from authoring tools, federating data from various and dissimilar databases, and triggering processes and workflows. Download Now
Research Report - Simulation-Driven Design for SOLIDWORKS Users
In this engineering.com research report, we discuss the rising role of simulation and the paradigm shift commonly called the democratization of simulation. In particular, we focus on how SOLIDWORKS users can take advantage of simulation-driven design through two analysis tools: SOLIDWORKS Simulation and 3DEXPERIENCE WORKS. Download Now
White Paper - Industry 4.0 and the Future of Engineering Education
With industries becoming more automated, more tech-driven and more complex, engineers need to keep their skills and knowledge up to date in order to stay on top of this wave—and to be prepared for the Industry 4.0 future. The University of Cincinnati offers two online Master of Engineering degree programs designed specifically for practicing engineers. Download Now
eBook - The Design Gridlock Manifesto
In this eBook, you’ll learn 6 ways old CAD technology slows your company down and hear how design teams have put those problems to rest. “The Design Gridlock Manifesto” shares first-hand modern CAD experiences from 15 companies around the world. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
