What is the relation between End time and Steps in simulation control?
Prashant Kumar24
1
Hello everyone.
I am simulating an impact test of my actuator. I noticed that when I keep my end time as 5 seconds and steps at 5000, i get a value different from the simulation with the same time but 10000 steps. How do i understand which numbers are to use for these two parameters in my simulation. How do i decide which gives me the correct value.
Thank you in advance!
 https://files.engineering.com/getfile.aspx?folder=7f4a7044-7de6-4c8e-8a42-63841d2b4d89&file=Capture.JPG
There's no harm in using a higher time resolution than a lower one (except in some weird cases). As such 10000 steps in 5 seconds is 'better' than 5000. Beacuse of the way the solver works there may not be much difference between them.
Cheers
Greg Locock
