FEMAP Buckling Analysis Help
I just recently started doing buckling analysis on FEMAP and have a few basic question:
- From research I have done, it seems that if my shell elements have offsets, I have to use CQUADR elements for buckling analysis. Is this true? Why is this the case? Why are CQUAD4 elements not viable?
- What role do parameters K6ROT and AUTOSPC play when it comes to buckling? My understanding is that the K6ROT value dictates the stiffness of the sixth degree of freedom. So then K6ROT should only be toggled if I am running buckling and not using CQUADR elements? AUTOSPC seems to deal with matrix singularities. So does it set degrees of freedom to zero with the stiffness matrix k? Should I toggle this on for all analysis and not just buckling?
- Lastly, I've done a fair bit of research online, but could someone point me to a reliable source of information on analysis setup for FEMAP?
Thank you in advance!!
