Only if someone makes a library to drive it or you create one yourself. Given the limited number of suppliers it may take a lengthy search to find a library that is compatible.
Edit:
Also - it does not appear to be an OLED -
2.8 320x240 tft lcd display SPI/RGB/MCU interface
You might look to see what the driver chip is and see if there is a library that mentions that chip.
