Linear solution keeps failing to converge
I have to parallel plates with a simple honeycomb in between (basically a sandwich structure). The bottom plat is fixed, the top one moves of a small amount in one in-plane direction. I need to see what happens to the honeycomb in shear buckling. The solution fails to converge. I reduced the time increment to 1e-07 and still I received a message it's not small enough. Shall I just keep decreasing it or is there another strategy I'm not aware of?
RE: Linear solution keeps failing to converge
Further decreasing initial time increment won’t help in this case. The error that you get is just a generoc message indicating nonconvergence. Here’s what you can try:
- check all warning messages
- make sure that all interactions (contact, tie constraints and so on) work properly and there are no rigid body motions/unconnected regions
- turn NLGEOM on if it’s off now
- use automatic stabilization in step settings
- refine the mesh and make sure that its quality is good
- consider using explicit solver
To give more detailed advice I would have to see the model. So, if you can, please attach a picture of it or, even better, share its files.
Here the input file. when the increment is 1e-05, it aborts after 5 increment. The lower I go with the increment the more iterations I get but still not enough for convergence. I thought about moving to explicit and I think I'll go there now. Thanks!
https://files.engineering.com/getfile.aspx?folder=...
To solve this in Abaqus/Standard you should include imperfections (imported from eigenvalue buckling analysis). And it might be easier to run the postbuckling study using Riks method.
Thank you for suggesting the Riks method, I was not aware of it and I will definitely look into it.
Regarding the *imperfection command: as far as I understood, I impose imperfections to my model that follow the path of buckling analysis. Is there a rule for the magnitude of the imperfections?
THank you
When defining impoerfections you have to specify scale factor for each mode. In case of shells it is advised to use a value order of magnitude lower than the shell thickness for the first mode and decrease the factor by half for each of the subsequent modes.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - PLM and ERP: Their Respective Roles in Modern Manufacturing
Leading manufacturers are aligning their people, processes, and tools from initial product ideation through to field service. They do so by providing access to product and enterprise data in the context of each person’s domain expertise. However, it can be complicated and costly to unite engineering with the factory and supply chain. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
