welding A514 to A516
afarboudi
NL
Hi
I need to know proper welding consumable for welding A514 to A516. unfortunatley I did n't find anything about this on the internet.
Can you help me guys?[smile]
The internet is not a welding engineer.
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
go to ASME IX and qualify your welding procedure.
luis marques
Use a low hydrogen SMAW electrode or other low hydrogen welding process. More information is required to be more definitive.
Best regards - Al
Don't be shy to call your welding supplier. Often they are are great resources when determining filler metals.
We weld A517 with SMAW 11018, that might be a good starting point if you don't need a high volume. Otherwise the Lincoln sells a ultracore 121K3C-H that might work in your application.
As already mentioned we don't have many details on what your application is, but these might be a good starting point.
If you gave us more information we could help more. PWHT, Thickness, impacts?
