Response Spectrum Analysis of Irregular Wood Structures - SAP2000
Mohzus
CA
Does SAP2000 perform RSA of wood structures? Is wood in the catalog of materials used?
I've zero experience in working with wood structures but still would be happy to share my thoughts on this.
I don't think so. But I guess you'll be able to custom define the essential material properties for wood, that is an orthotropic material, using advance material property data option.
Most software perform analysis using stiffness matrices which basically requires three main inputs.
Modulus of elasticity of the materials; E,
Cross-sectional properties, A & I and
Length of the members L.
So as far as only analysis of wood structure is concerned then the answer IMO will be, Yes.. Sap2000 may give you correct analysis results if you have accurately defined the material model, geometry of the frame and the provided joint stiffneses.
As far as "Response spectrum analysis" is concerned, it is nothing but a combination of analysis, performed for base shears corresponding to the time periods of each mode shape. These mode shapes are obtained from modal analysis which determines the deformed shape of your structure, based on defined stiffness and mass matrices.
Thus, again, if you've correctly input the data used for assembling the stiffness matrix then, sap2000 may give reliable results.
Having said this all, someone with experience in design of wood structures could give you more dependable response.
