Masonry building with Shell , Bendig Modifiers choices and more
kopernikus
GR
For a masonry building I have chosen to simulate the walls with Shell-Thick.
1)I would like to ask if the wall thickness is 60cm, in the field Thickness and Membrane and Bendig I will put 60cm ?(the same?)
2)In the Stifness Modifiers choices do I need to change anything?
