1
- #1
Do speed + direction sensors for back-biased / gear-tooth applications, such as Honeywell SNG-Q Series, use two separate hall IC's?
I cannot find any single hall IC's for back-biased applications which provide speed + direction detection with quadrature output, other than the Allegro ATS605, but I doubt all speed senor manufacturers can be using this sensor.
