from previous post seems like.
Once20036 (Structural)4 Apr 17 21:11
Why not call the manufacturer?
The ability of decking to handle negative flexure will vary based on the specifics of the deck.
The deck we typically specify has bearing bars in one direct, and small rounds in the other direction. These rounds will brace the compression side of the bearing bars for positive flexure, but not negative flexure. Like the cantilever beam over a column/inflection point bracing question that comes up routinely, if you're using this type of deck you`ll have a huge unbraced length for the compression (bottom) flange, and hence very little capacity.
once20036 is the only one who knows anything.
like so often today you call and no one knows anything. they have no idea what unbraced length is. world is getting scary.
Need help multiple span grating large grating 5"x 1/4" 3'-6" spans three span.
reference, bearing bar and unbraced lengths. heavy loads. and need help anchoring down to steel with a clip.
