Contact US
rigid connections steel frame
Hi! I have a problem with abaqus.
I need to create a steel frame with rigid connections between the beam ends and the columns.
I create 3D wire part for the beams and columns, and I assigned the material, profile and section. After I assembly it, and I create the steel frame. How can I realize the rigid connections between the elements?
Thx in advance
RE: rigid connections steel frame
You can use tie constraints or merge parts to realize this type of connection.
A screenshot, drawing or sketch would help to understand your question.
If you connect the wire geometrically, then you get common nodes during meshing and the rods are connected to each other.
Otherwise you can use a Tie-constraint or add connector elements between two nodes and use the connector type 'Beam', which is a rigid connector.
Tie constraints are the best option in such case. Just apply them to all rigid joints (select the two ends of wires connected at a given joint). You may have to change position tolerance if default one turns out to be insufficient.
Hinged connections can be realized using equation constraints.
Thx for your response.
I connect it geometrically and I create a reference point for every floors. In this point I create a Kinematic coupling constraint and I assigned the intertia mass.
But when I try to do the Jobs to evaluate the frequency Abaqus give me this error: Too many iterations needed to solve the eigenvalue problem.
I also try to evaluate only the first shape mode.
Kinematic coupling is not a good option in such case (I assume that you want the mass to be applied to the whole beam, not just a single node). Check this thread with the discussion about the application of remote mass in modal analysis:
https://www.eng-tips.com/viewthread.cfm?qid=460924
I solve the problem, but the foundamental period is 8.47*10^-22.
There is another strange thing, in the deformed beam, a beam moves, like it's coming off the frame. I don't understand why!!!!
Did you use tie constraints ? If yes then you should increase the position tolerance. Modal analysis is the best way to visualize disconnected regions and as you say, they occur at frequencies close to zero.
No i connect beam and columns geometrically. I try to use tie constraints.
If you want them to be connected geometrically you have to make a single part from them. It can be easily done in the Assembly module (using Merge/Cut Instances tool that I've mentioned before). Mesh nodes can be merged this way too.
Sorry but I don't understand.
I do Merge/Cut in Instance tool. I select Merge (Mesh), in options Suppress and in Merge nodes boundary only.
When I do the analysis there is another error: In model....have not assigned a beam orientation, ecc...
But when I create the beam I assigned the beam orientation...
I'll write down the steps I took
1) I create wire part for every type of beam/column
2) I create steel material
3) I create I profile for every type of beam/column
4) I create sections for every type of beam/column
5) I assign section and orientation at every beam/column
6) I assembly the parts with Independend (mesh on istance) and i create my frame
7) I create the step for the modal analysis
8) I create boundary conditions (Encastre) at the foundation
9) I create kinematic coupling constraint every floor with a special join in the centre of gravity. I assign to it the inertia
10) I create the mesh
Merge/Cut Instances tool creates a new part and instance so you may have to reassign orientations. You can check if they are assigned or not using Query tool in the Property module.
I have combined the various elements, but I have another problem.
The periods grow with the number of mode and they are very big.
what could be the problem?
Take a close look at the mode shapes (deformations). Do they look correct ? Aren't some parts of the frame disconnected and moving on their own ? Make sure that all units are correct (dimensions, material properties and point mass/inertia values).
All the parts of the frame are connected, i check it. I think that a possible problem is the units, but i don't understand why the periods growing!?!?
Do you mean that each of the subsequent modes has higher eigenfrequency ? This is normal, natural frequency extraction procedure finds either selected number of subsequent modes or all modes in a given range of frequencies. Then it displays them in order from lowest to highest frequency.
Yes i solved the problem. thx!!!!
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
