Cryogenic System
Fluids101
Aerospace
Mar 9, 2020
1
Hello all,
I'm newer to cryogenics design, but have a few questions after reviewing some simple LN2 transfer schematics:
1. I know it's required to have relief valve between any two valves, but is it required to have a relief valve between a regulator and valve too?
2. Are accumulators used in a cryogenic system for energy storage like pneumatic, or a different purpose like vibration/shock reduction?
3. I'm noticing a lot of valves in parallel. Is this mostly for fast fill, chill down or replenish?
Thank you
A thermal relief is required for any trapped liquid volume scenario. Assuming a volume between a manual valve and a liquid regulator (maybe on a PB circuit) a thermal relief must be included since the regulator may close.
F101...
Aircraft or Missile or ground-storage/transfer or...?
Any Cryogenic system... especially fuel/oxidizer liquids... system design, is extremely serious business.
'War-story'...
Rainy days in a row... several empty 'LOX bottles' [can't remember formal term for cryogenic liquid storage containers, right now] for a 'jet' [squadron] were filled and transported to the ramp for installation in jets, prep for mission in an open-air cart.
LOX bottles were installed by technician who 'failed' to ensure that relief valve ports on bottles and the Acft LOX compartment-vents were 'free/clear' of moisture/ice.
Yep... as bottles warmed-up in the jets, ONE of the bottles was unable to vent-off GOX... pressure built-up and about 1-hr after servicing the LOX bottle was over stressed and catastrophically ruptured... almost severing the fuselage thru the LOX compartment... major structural repair at depot was required [+2 years].
Regards, Wil Taylor
o Trust - But Verify!
