A simple question about SAP2000 API , Matlab
arefi
DE
thread801-309262
I read the topic above, but I couldn't understand what the writer did to solve his problem.
I also have built a model using SAP and saved it. Then I used the following code to open and analyze it using MATLAB interface. The problem is, I can't get any "Joint Displacement" results by API codes, and I get this error No method 'FrameForce' with matching signature found for class 'SAP2000v20.cAnalysisResults'.
I would REALLY appreciate any help
%% clean-up the workspace & command window
clear;
clc;
%%set the following flag to true to attach to an existing instance of the program otherwise a new instance of the program will be started
AttachToInstance = true(); % false(); %
%% set the following flag to true to manually specify the path to SAP2000.exe
%% this allows for a connection to a version of SAP2000 other than the latest installation
%% otherwise the latest installed version of SAP2000 will be launched
SpecifyPath = false(); % true(); %
%% if the above flag is set to true, specify the path to SAP2000 below
ProgramPath = 'C:\Program Files\Computers and Structures\SAP2000 20\SAP2000.exe';
%% full path to API dll
%% set it to the installation folder
APIDLLPath = 'C:\Program Files\Computers and Structures\SAP2000 20\SAP2000v20.dll';
%% full path to the model
%% set it to the desired path of your model
ModelDirectory = 'C:\Users\User\Model';
if ~exist(ModelDirectory, 'dir')
mkdir(ModelDirectory);
end
ModelName = 'sample_bridge.sdb';
ModelPath = strcat(ModelDirectory, filesep, ModelName);
%% create API helper object
a = NET.addAssembly(APIDLLPath);
helper = SAP2000v20.Helper;
helper = NET.explicitCast(helper,'SAP2000v20.cHelper');
if AttachToInstance
%% attach to a running instance of Sap2000
SapObject = helper.GetObject('CSI.SAP2000.API.SapObject');
SapObject = NET.explicitCast(SapObject,'SAP2000v20.cOAPI');
else
if SpecifyPath
%% create an instance of the SapObject from the specified path
SapObject = helper.CreateObject(ProgramPath);
else
%% create an instance of the SapObject from the latest installed SAP2000
SapObject = helper.CreateObjectProgID('CSI.SAP2000.API.SapObject');
end
%% start Sap2000 application
SapObject.ApplicationStart;
end
helper = 0;
%% create SapModel object
SapModel = NET.explicitCast(SapObject.SapModel,'SAP2000v20.cSapModel');
File = NET.explicitCast(SapModel.File,'SAP2000v20.cFile');
%% assign isotropic mechanical properties to material
RE=struct('e',zeros(100,1),'Dis',zeros(100,1));
PropMaterial = NET.explicitCast(SapModel.PropMaterial,'SAP2000v20.cPropMaterial');
ret = PropMaterial.SetMPIsotropic('C25', 2500000, 0.15, 0.00001);
%% refresh view, update (initialize) zoom
View = NET.explicitCast(SapModel.View,'SAP2000v20.cView');
ret = View.RefreshView(0, false());
%% save model
ret = File.Save(ModelPath);
%% run model (this will create the analysis model)
Analyze = NET.explicitCast(SapModel.Analyze,'SAP2000v20.cAnalyze');
ret = Analyze.RunAnalysis();
%% initialize for Sap2000 results
SapResult = zeros(2,1,'double');
%% get Sap2000 results for load case
AnalysisResults = NET.explicitCast(SapModel.Results,'SAP2000v20.cAnalysisResults');
AnalysisResultsSetup = NET.explicitCast(AnalysisResults.Setup,'SAP2000v20.cAnalysisResultsSetup');
NumberResults = 0;
Obj = NET.createArray('System.String',2);
Elm = NET.createArray('System.String',2);
ACase = NET.createArray('System.String',2);
StepType = NET.createArray('System.String',2);
StepNum = NET.createArray('System.Double',2);
U1 = NET.createArray('System.Double',2);
U2 = NET.createArray('System.Double',2);
U3 = NET.createArray('System.Double',2);
R1 = NET.createArray('System.Double',2);
R2 = NET.createArray('System.Double',2);
R3 = NET.createArray('System.Double',2);
ret = AnalysisResultsSetup.DeselectAllCasesAndCombosForOutput;
ret = AnalysisResultsSetup.SetCaseSelectedForOutput('DEAD');
[~, NumberResults, Obj, Elm, ACase, StepType, StepNum, U1, U2, U3, R1, R2, R3] = AnalysisResults.JointDispl('893', SAP2000v20.eItemTypeElm.ObjectElm, NumberResults, Obj, Elm, ACase, StepType, StepNum, U1, U2, U3, R1, R2, R3);
SapResult(1) = U3(1);
[ret, NumberResults, Obj, Elm, ACase, StepType, StepNum, U1, U2, U3, R1, R2, R3] = AnalysisResults.FrameForce('484', SAP2000v20.eItemTypeElm.ObjectElm, NumberResults, Obj, Elm, ACase, StepType, StepNum, U1, U2, U3, R1, R2, R3);
SapResult(2) = U1(1);
end
