Time at Last Converged Solution
KBob1
1
Looking for some advice. I want to do some parametric limit load analysis using Ansys Workbench. I need to make the time at the last converged solution (same as restart time)a parameter. I want to use an APDL Solution command line (i.e., *GET,My_Value,...) to get the Commands(APDL) Result and then make it parametric. I can't figure out how to do it. The value I need is shown in the Solution Information. Thanks
