Explicit meshing - what to do with sharp corners
I am modelling crash and drop test for parts with a lot of very small radius features (<1mm). In order to get the run time to reasonable numbers I have to remove these radius features and most of the time I get sharp corners. When using implicit schemes I now this is a big no no, but in explicit I don't really have a choice (a few days run times are out of the question).
How do you tackle this issue? From my understanding sharp corners are less problematic in explicit analysis due to the dynamic nature of these problems, am I wrong?
Thanks.
RE: Explicit meshing - what to do with sharp corners
That’s right, in explicit you can (or even should) remove the small features such as rounds/fillets. It won’t affect the accuracy significantly but will increase the stable time increment and thus speed up the analysis.
Thanks for the input
You should only model those radii that really matter (you want to know exact stress in that region).
If even this makes the runtime unreasonable, you could use mass scaling for those small elements.
Yes, smart mass scaling with a target time increment can help a lot in such cases.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - How ESI is Helping Move New Medical Device Product to Market Quicker & More Cost Effic
Early Supplier Involvement has long been a strategy employed by manufacturers to produce innovative products. Now, it almost seems like a necessity. Because decisions made in the design phase can positively affect product quality and costs, this can help add value to OEM bottom lines. This white paper will discuss many facets of ESI, including why it’s so valuable today, what challenges limit the benefits of ESI, how cost is impacted, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
