Pipe designing/routing for cryogenic fluids and gaseous oxygen
Hi there,
I'm just new in my job and the area of business are very different to my old one. In general I do know how to design pipes and route them, but since now I never handled that kind of liquids / gases and I try to figure out where the differences are for designing pipes between "normal" fluids / gases and cryogenic / explosiv ones are.
The pipes I'm talking about is for example going from a seperator to a flare stack.
Particular I'm looking for advice about:
  • max. allowable velocity in pipes
  • is there a minimum straight lengths for a pipe I have to have (without having trouble with micro particles getting in the elbow)
  • max. allowable velocity in pipes (fluid/gaseous)oxygen
Hope I made myself clear enough, if not please say so and I'm happy to be more precise!
Any advice will help and thanks for that in advance!
Looking forward to read some :0)
RE: Pipe designing/routing for cryogenic fluids and gaseous oxygen
This looks like a good start
https://www.eiga.eu/index.php?eID=dumpFile&t=f...
try googling oxygen system piping design
Max velocity is always a touchy subject and there are many such posts on this forum and the usual response is "it depends".
Oxygen for sure is a tricky fluid, but I don't know if there is really much difference in thepiping design.
no one wants the pipe to leak for any substance.
It's often more about material selection and stress analysis / expansion and contraction.
Not a full answer below but hopefully a part of it.
Gaseous oxygen velocity in piping is limited to 60m/s for non-impingement which decreases with increasing pressure. 30m/s for impingement scenario.
Although I don't know any reason for other gases to surpass that velocity, my company use that same restriction (oxygen) for other gases. See BCGA CP4 (which references eiga IGC Doc 13/12/E) may give you more helpful information.
Sadik
With cryogenic fluids you have to worry about when two phase flow starts to become an issue for the end user. Even with vacuum jacketed piping, heat gets in and you have phase change of some percent of the liquid depending on how long the lines are. Enough pressure drop from flow can also cause two phase flow issues.
One area for oxygen service that's also a bit tricky is deciding how to clean the pipes for oxygen service.
With oxygen everything is temperature and pressure dependent. The critical velocity is rarely in the piping, it is in the valves. I have seen the aftermath of the wrong seat material in a control valve. It burned up a couple of tons of steel before they got it shut off.
Most pure oxygen systems are built of SS for both cleanliness and protection from ignition.
There are a lot of good NASA references from the 1960's with good basic information in them also.
Start with these guys
https://www.cganet.com/
P.E. Metallurgy
Thanks a lot for all the answers!
@littleInch: od course I did google at first, but it wasn't that satisfying ;0)
@shussain786: thanks to you too. It is a good start!
@jari001: indeed! It's the same if you see that someone designs a flashbox and don't think about that part of the fluid get's gaseous and needs far more space in the flashbox ...
@EdStainless: Indeed again! Seen this problem in professional life as well ... And thanks to you to! I think I have now a good point where I can start off :0)
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - How to Capitalize on HVAC/R Trends to Drive Business Growth
According to Steve Yurek, CEO of the Air Conditioning, Heating and Refrigeration Institute, the HVAC/R industry is facing change on all fronts. This includes challenging trends on contractors and distributors like new refrigerants, growing automation, complex sensors and monitoring, green initiatives and a technician shortage. We look at these trends and outline actionable insights on how it all can be turned into a competitive advantage and business opportunity. Download Now
eBook - Manufacturing the Cars of Tomorrow
In this ebook, we'll explore how additive manufacturing is going to transform the way cars are made. This includes commentary from thought leaders such as Ford's CTO, Ken Washington, Customer case studies of ways 3D printing is being used today, and a variety of part examples where 3D printing is already impacting how automobiles are made. Download Now
White Paper - Smart Manufacturing for Semiconductor
New technologies and approaches present great opportunities for semiconductor manufacturers to achieve high levels of innovation, yield and improvement. This white paper explores some of these cutting-edge technologies and how they can be applied effectively in the semiconductor industry. Read about how Smart Manufacturing is transforming the semiconductor industry. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
