Strange gearbox tooth pattern
Hello Guys,
in attachments you found some photo about strange gearbox tooth pattern found. Before the inspection i made some vibration measurement on it discovered this:4
-1XM in axial 13,5 mm/s
-2XM in radial 16 mm/s
-1XGMF 2mm/s
THis machine is forming roll in a papaer machine (MOTOR-PENDULUM GEAR-CILYNDER).
All of your consideration about tooth pattern will be helpfull.
-1XGMF 2mm/s
RE: Strange gearbox tooth pattern
(2B)+(2B)' ?
TTFN (ta ta for now)
Walt
Walt
Based on the contact pattern, i would recommend you to check for the axial play in the bearing. I hope the gear is mounted on a set of taper roller bearings. Kindly ensure that the pre-loading in the taper roller bearings are fine. I hope that this should solve the problem. Further, I feel that there has been an initiation of micro pitting in the gear flank. Kindly check for the viscosity of the oil and also for the presence of any abrasive/metal particles in the lubrication oil.
K.Kaarthic
some suggestions
attach a magnetic base with a dial indicator on ground surface, and look for excessive runout.
could be a worn bearing , or miss alignment.
a rebuild of this gear box is required, the pinion gear is worn.
the vibration is the teeth interfering causing excessive wear.
a full failure analysis will be required, a qualified engineer or technician or both, will have to
tear down the box and document and take pictures of each component.
document were and how the failure occurred.
Walt
