Process Mike
Industrial
Recently , a plant manager was suspecting that trapped air in thermal fluid bitumen tank coil could significantly impact the heat transfer performance . He might be right depending the air amount inside the heating coil :
DATA : 2 in sch 80 , A 106 coils , 500 ft lenght , butt welded with many 180 U bends to acheive the bottom tank coil
Inside coil : Therminoil heating fluid at 375 - 400 F , fluid speed 2 ft / sec , pressure 20 psig
My idea was to increase thermal fluid coil velocity ( by increasing flow) from 2 ft/s to 8 ft / sec
At this speed , any air bubbles inside the coil will be entrained into the flash tank , then air will be eliminated
We performed a bench test with water pipe and it is OK ... NO REMAINING AIR inside 2 in . pipe
MY QUESTION :
is there any empirical formula that could give me a minimal fluid speed to respect in order to make sure air bubles will be entrained out the coil , to the flash tank ? ( including viscosity, sp gravity , pipe diameter ect ...)
I read a LOTS of stuff on many forums , but found NOTHING ....
Thanks for your recommendation
MY QUESTION :
