Buildtech2
As per attached ASHRAE reference, the recommended lowest chilled water pipe velocity to be maintained in chilled water pipes is 0.6 m/s. In my current fit-out project, I have to use existing chilled water pipes for new fit-out flow rates where the pipe velocities are dropping below 0.6 m/s. I am assuming there won't be any major impact with such lower velocity. Appreciate, if anybody can advice on this issue.
