Tolerances between parts of mold for injection molding
Azzazil
Automotive
HR
Hi, I am interested in injection molding and recently I finished this tutorial How To Create a Mold— Part 1
Now I started to work on drawings,I am curious how can I determine tolerances between dowel pin, top insert and upper mold plate.
For what type of fit should I go, between this parts? Also I am inserting top insert into upper mold plate, do I also have tolerances for fit between this two parts? I am using tolerances by ISO 286, and I use centreline of plate to annotate feature of size, is it maybe better GD&T with tolerance of position?
Here is step file and drawings of top insert and upper mold plate.
 https://files.engineering.com/getfile.aspx?folder=22539194-c626-44bf-bef9-a42186c9bae8&file=Injection_mold_question.7z
