Hypoid Spiral Bevel Gear Force Math (tooth & bearing)
binsky3333
Computer
Hi everyone!
I have a computer science background (this is my first big personal ME project)... so don't be too harsh on me heh. [tongue]
I have a hypoid spiral bevel gear set that I am designing a new case for. The original case is very cheap cast aluminum that breaks very easily. This piece is a transfer case thats send power from the front of the car to the rear wheels.
I am working on calculating the gear tooth forces and then calculating the forces on the shafts. I have already prototyped the case for testing gear fitment but want to calculate the forces and then do some FEA on my prototypes before I go any further.
Here is a picture to get an idea of what I am talking about. The torque is input through ring gear (yes you read that correct) and output through the pinon.
I have been using the following website to calculate the gear teeth forces :
Specifically this table... from my understanding of bevel gears the tangential force is calculated the same way for all types and only the axial and radial change based upon whether its straight, spiral, zerol, etc.
Ignore the values in this table, they are just example values.
I did some calculations by hand in excel, but found out the KHK Gears website had an online calculator using the exact table above. I ran a calculation with ~3300nm of input torque on the ring gear (or 1000nm output on the pinon, 3.31 ratio). I came up with the following:
Now that I knew my tangential, radial and axial gear tooth forces I could calculate the actual forces on the bearings. To do that I use the following two websites:
(I used page 3 to calculate the tangential, radial and axial and then combined)
(This I used to just get an idea on the tangential forces on the bearings but also has good info on calculating combined)
This is where I started second guessing myself. The gear tooth forces seemed pretty realistic to me and I found the same math on a lot of different websites indicating its pretty standard stuff. I did however have some trouble finding how to calculate the forces on the bearings. I know I need to calculate the tangential, axial and radial on each of the bearings, then I can calculate the combined radial load using those 3 and use that in my FEA sim along with the axial load.
But first I wanted to get an idea of the tangential forces on the bearings.
In this case with the pinon:
A - 35mm
B - 80mm
C - 45mm
Kt - 62961N from the calculation above (tangential only for now)
FrA = 80/45 * 62961 = 111930N
This just doesn't make sense to me. How is the tangential force on the bearing nearly double that of the force on the gear tooth?
On the stock motor that this transfer case is from, the engine torque is about 300nm, then that goes through 1st gear and the final drive (which this transfer case is directly coupled to). So 3000 * 12ish = ~3300 and bearing A in the stock TCASE is only rated for 105,000N so now way stock torque is already creating forces over the bearing rating.
Am i on the right tract here guys? I must be missing something.
Any and all help is much appreciated.
i think you are talking about radial Force on the bearing and gear.
FrA : Radial load on bearing A [N]
FrB : Radial load on bearing B [N]
K : Radial load on gear [N]
look at the direction of both FrA and FrB, the summation of both (one negative and the other is positive) will logically generate correct value of K.
what i mean is that, summation of forces in y direction is ∑Fy = FrB - FrA = K
R.Efendy
Hi R.Efendy,
Thank you for the response.
I must've missed that FrA and FrB were in different directions. The numbers make sense now.
So... I've done more reading and research on the gear tooth forces and I believe that those are being calculated right.
I am basically going to proceed now with calculating FrA, FrB, FrC, FrD in the tangential, radial and axial directions. Then I will proceed to calculate combined radial which is comprised of all 3 and axial is axial.
I can then use combined radial and axial in my FEA model.
I will use the following, but obviously the directions will be different based upon the spiral direction of the ring & pinon as well as the driving gear.
you are on the right track now and that make more sense. good luck.
R.Efendy
Down load a free trial of MIT calc or kisssoft. A free 30 day trial. Then go to town on the calcs.
Use the correct data on the material.
HP force, RPM, and torque.
All of the gear data must be correct
It will calculate the safety factors. I use it on spiral bevels, helical's and spiral bevels.
Do a search on the gear And pulley threads and look for the Fairfield gear program.
It does the same. But it may only run properly on 32 bit windows.
Make a virtual, throw Windows XP on it.
Your good to go.
I would just do it in CAD like SolidWorks on solid models of the gears. Two options. 1. Place a normal in the middle of the tooth surface and measure the required angles. 2. Assemble the gears with a small interference and subtract - you will get a face on the tooth surface - immediate tooth contact. Use this face to apply force or place normals. Agree, that you would need an accurate 3d CAD model of the gear teeth, but you will need them any way for correct 5-axis CNC tooth machining. google for spiral bevel software in order to get correct 3d tooth surface. KIssSoft is one of the options but I think it is Gleason now.
