repair welding of a cracked compressor disk
Hi to All,
We are going to repair welding of a cracked compressor disk. The cracks are formed due to low cycle thermal fatigue. The disk material is ASTM A471 class 12 (Fe-0.45C-0.8Mn-1Cr-0.5Mo). We should qualify the welding procedure before welding on the disk. However, A471 is not available to make a test plate for welding qualification. Is it possible to use another material for making a test plate for qualification purpose? Are 4140 or 1045 steel being suitable choice? Would you please comment on this matter?
Many thanks,
Nima Javan
Many thanks,
Nima Javan
RE: repair welding of a cracked compressor disk
So do you know the exact HT on your disc?
P.E. Metallurgy
Distortion and residual stresses are potential concerns that a weld qualification test gives no information about.
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
Then you can work with pre-heat, welding, and PWHT.
Since this is a rotating componant you are really going to need to look at toughness and NDT.
P.E. Metallurgy
What operating temperatures are involved?
Is the disc to be repaired in situ? (So no PWHT as mentioned by others)
Will the operating conditions that caused the cracks continue?
If so, I'd be plenty scared that weld repairs will be quite short lived and develop cracks of their own.
Have you determined how deep the cracks are?
Are they in a location of high and significant hoop stress ?
Sometimes if grinding parts thinner by 10% or less, with large gentle radiuses and with excellent craftsmanship removes the indications it can be a satisfactory repair.
I'd follow up the grinding repair with shot peening.
Thanks for your comments.
The picture is attached. The cracks initiated from the balance holes on the surface of the disk. Some cracks are through thickness (i.e., the depth of some cracks is about 4 cm!). The cracks are probably formed due to thermal fatigue as a result of start up and shout down thermal stresses. The operating temperature is about 300 oC. The life of the disk is about 150,000 h. The hardness of the disk is about 240 HB with a tempered martensite microstructure.
The simulation results showed that the stress in the cracked region is about 350 MPa.
We should weld with sufficient pre-heat and then immediately PWHT using proper conditions.
Would you please give me your idea about GTAW filler metal selection? Two options are plausible. The first, is the use of match filler metal (e.g., ER110 or ER120). The second is the use of an undermatch filler metal (e.g. ER80) to reduce the susceptibility of cold cracking. What is your opinion?
Scrap and replace.
Keep in mind, any significant defect can (will) cause cracking to reappear.
While I regularly advise on difficult repairs, I do not feel confident on the (practical) feasibility of this one...
Precisely the basis for my advice.
BTW I have to wonder when I see balancing holes 180° opposite each other.
Thanks for your advise.
Thanks for your advise. You mentioned that " I have to wonder when I see balancing holes 180° opposite each other ". Would you please explain a little bit more? Thanks.
Did your simulation include disc rotation as well as thermal goings-on ?
If just one or 2 I'd be mighty tempted to machine out the cracks with a ball end mill and call it good. Machine a similar detail opposite in an effort to maintain balance.
Will the rotor be re-balanced with the blades installed? Is there an OEM procedure how to seat the blades ( rev it to XXXX rpm )
if the part is to be balanced as an assembly.
I'd Also machine a radius on all the holes to improve the stress distribution.
Whacking/pressing a large ball bearing into each hole entry to create a chamfer loaded with compressive stresses might be of more benefit.
"Significant" holes opposite each other suggests a severe over-correction, or the set up was bad, and then fixed, or the operator mistakingly drilled on the light spot ( doh !!), or something.
